BRAXTON CREEK (USA) Bushwhacker Plus Previe10
Le deal à ne pas rater :
Etui de protection pour iPad
15 €
-98%
Chargeur sans fil – Samsung EP-P1100 Intérieur – ...
0.32 € 20.43 €
BRAXTON CREEK (USA) Bushwhacker Plus Empty BRAXTON CREEK (USA) Bushwhacker Plus
Message par schoq le Jeu 23 Jan 2020, 14:32
BRAXTON CREEK (USA) Bushwhacker Plus Logo
BRAXTON CREEK (USA) Bushwhacker Plus 15-img10
[Vous devez être inscrit et connecté pour voir ce lien]BRAXTON CREEK (USA) Bushwhacker Plus 1-img-10
[Vous devez être inscrit et connecté pour voir ce lien]BRAXTON CREEK (USA) Bushwhacker Plus 16-img11
Bushwhacker Plus
BRAXTON CREEK (USA) Bushwhacker Plus BushwhackerPlus-1577865533
specs
  • Starting From Price (MSRP)0
  • Exterior Length15' 6"
  • Exterior Width6' 9"
  • Exterior Height8' 6"
  • Axle Height0
  • Interior Height0
  • Unloaded TT Weight0
  • DRY Weight1900 lbs
  • Gross Vehicle Weight Rating (GVWR)3000 lbs
  • Cargo Carrying Capicity925 lbs
  • Fresh Water Capacity21 gals
  • Gray Water Capacity18 gals
  • Black Water Capacity8.5 gals
  • Sleep Capacity2
  • L.P.Gas1 - 20# BOTTLES 5 LBS.
  • Outside Kitchen--
  • Awning Length0
  • Tag For Floorplan0
  • Slideout--
  • Optional Additions--
  • Dry Hitch260 lbs
  • Axle Weight1640 lbs
  • Exterior Box Length12' 6"
  • Frame Size5 1/4"
  • Tire SizeST235/75R15C
  • Tire Rated Load2340# @ 65 PSI
  • Rim Size15 X 6 J
  • Rim Rated Load2860 lbs
  • Gross Axle Weight Rating (GAWR)3000 lbs
  • Gross Axle Capacity3000 lbs
STANDARDS & OPTIONS
Specifications
  • 2-Burner cooktop with glass cover
  • Kitchen sink with integrated faucet
  • LED interior and exterior light package
  • Blue-tooth ready Stereo with speakers
  • 110V and USB ports
  • 5000btu A/C
  • Multi-directional TV antenna with WIFI prep
  • TV Prep package
  • Go-Power Solar prep pkg
  • Spare tire and integrated carrier
  • 6-gal DSI gas/electric water heater
  • 12,000btu furnace
  • 3-Way Refrigerator
  • 12-volt high-output attic fan
  • 21 Gal. fresh water tank
  • E-Z Swap LP Tank
  • 2 Rear BAL Stabilizing Jacks
  • E-Z Bed/Dinette System
  • Expanded "wet-bath" with integrated shower/toilet enclosure
  • Over-sized, all-terrain Radial Tires, with Alloy Aluminum Sport wheels
  • 3000lbs High-Clearance, torsion-flex, Independent axle
  • Norco, stamped steel, e-coated mainframe
Voir la Brochure en PDF
