BRAXTON CREEK (USA) TearDrop-Bushwhacker Previe10
-34%
Le deal à ne pas rater :
Samsung Gear VR – Casque de Réalité Virtuelle ...
17.24 € 26.00 €
-44%
Fauteuil gaming Arozzi TORRETTA noir
139.99 € 249.00 €
BRAXTON CREEK (USA) TearDrop-Bushwhacker Empty BRAXTON CREEK (USA) TearDrop-Bushwhacker
Message par schoq le Jeu 23 Jan 2020, 14:10
BRAXTON CREEK (USA) TearDrop-Bushwhacker Logo
Tear Drop-Bushwhacker
BRAXTON CREEK (USA) TearDrop-Bushwhacker ClassicTearDropII-1556718228
[*]Starting From Price (MSRP)--
[*]Exterior Length13' 2"
[*]Exterior Width6' 9"
[*]Exterior Height6' 10"
[*]Axle Height12"
[*]Interior Height--
[*]Unloaded TT Weight1,300 lbs
[*]DRY Hitch Weight120 lbs
[*]Gross Vehicle Weight Rating (GVWR)2,200 lbs
[*]Cargo Carrying Capicity817 lbs
[*]Fresh Water Capacity10 gals
[*]Gray Water Capacity0
[*]Black Water Capacity0
[*]Sleep Capacity2
[*]L.P.Gas--
[*]Outside KitchenYes
[*]Awning Length--
[*]Tag For FloorplanNEW FOR 2020
STANDARDS & OPTIONS
Interior FEATURES
  • Under Bed Hidden, Padded Storage Boxes
  • 4-Inch, Deluxe Comfort, Quilted Bed Mattresses
  • Multiple 110V, 12V & USB Outlets, Conveniently Located Throughout
  • 5,000-BTU Wall-Mounted A/C
  • AM/FM Bluetooth Compatible Stereo w/Interior & Exterior Speakers
  • Conveniently Located LED Lights Located Throughout
  • Oversized Storage Cabinets
  • Prepped for TV w/Cable Plug & Multi-Directional TV Antenna
  • 12V, 3-Speed Vortex Roof Vent
  • Coleman 12V Refrigerator/Cooler
  • 24 gal. fresh water tank
       2020 Enhancements
  • 12,000 btu furnace, with wall mounted thermostat
Exterior FEATURES
  • Torsion-Flex 2,200-lb. Independent Suspension Axle w/Electric Brakes & Maxi-Clearance Design
  • Oversized All-Terrain Radial Tires w/Apex Gun-Metal, Rally-Sport Wheels
  • Heavy-Gauge, Powder-Coated Wheel Fenders
  • Oversized, Lockable Entry Doors w/Built-In Slider Windows
  • Welded, Aluminum Framed, Main Coach-Body Construction
  • .040 Smooth Painted Aluminum Exterior Siding
  • High Density, Solid-Block Foam Insulation
  • Dual Rear, Heavy-Duty Extendable BAL Stabilizing Jacks w/Foot Pads
  • Norco Stamped, Heavy-Gauge Steel, Powder-Coated Mainframe w/EZ-Extend Hitch Jack
  • Van-Tech Roof-Mounted, Multipurpose Gear Rack
  • 30-AMP Converter w/30’ Detachable, Easy-Store Power Cord
  • LED Exterior Lighting Package
  • Dometic Combo, 2-Burner Gas Cooktop w/Built-In Sink, 10-Gal. Fresh Water Tank & Shur-Flo 12V Water Pump
  • Heavy-Gauge, Powder-Coated Dual Battery, LP Tank & Generator Mounting Platform
  • Under-Mount, Hidden Spare Tire w/EZ-Crank Access System
  • Easy-plug Solar Prep Package
Voir la brochure en PDF
